We have several drawings in which the BOMs are separate drawings (i.e. drawing is 123, BOM is PL123). Is it possible to generate a BOM from an assembly drawing but have it as a separate drawing?
I do what Tony Cantrell is suggesting. Works great. Just a word of cautioon, if you reorder the BOM to be out of line with the feature tree, you will cause errors. Under thr properties of the BOM make sure you select the "Follow Assembly Order" option.
Use another sheet instead of another drawing, as Igor stated, you can just drag the BOM in the other sheet and it'll display all you need.
I am working with aircraft drawings that were created in 1973. Their philosophy at the time was that the actual assembly drawing would have its assigned part number. The parts list was created as a separate drawing (ASME standards allow this) and was assigned a different unique number. Usually it was the assembly drawing number with "PL" in front of it. This si the format of the aircraft drawings and I need to follow that format
Can't you just do a seperate drawing for the BOM and hide the view you used to generate your BOM? That would give you the intended result IMO unless there is a little more info I am missing.
Edit: That is what Tony Cantrell meant. Create the view of your assembly and just move it out of the sheet space. Or you can just hide it, does the same!
In the FAQ that I linked to above I explained that after inserting a BOM you can delete the drawing view instead of hiding it or moving it off the sheet. After being inserted a BOM maintains a link to the Assembly itself, not the drawing view.
As far as I am aware a BOM has to be linked to a drawing view in the same drawing file, however you could make the scale of the drawing view very small and drag it off of the sheet.
