Macro to create Flat Pattern configurations in .SLDDRW
Question asked by Ali Chen on Feb 14, 2018
Latest reply on Feb 16, 2018 by Ali Chen
Hello All,
I am new and excited to learn about SolidWorks API and creating Macros.  I am currently working with a sheet metal part with bends and many configurations. The macro starts in .SLDPRT and a .SLDDRW template will appear. The part will be pulled from model view and flat pattern view is created along with a SM-Flat-Pattern for every configuration in part. After a few records and research in the forums, this is where I currently am. The DWG Template appears, but the part does not appear in the .SLDDRW.  Your help is much appericated.
Dim swApp               As SldWorks.SldWorks
Dim swModel             As SldWorks.ModelDoc2
Dim swDraw              As SldWorks.DrawingDoc
Dim swPart              As IDrawingDoc
Dim sConfigName         As String
Dim vConfs              As Variant
Dim i                   As Integer
Dim bView               As Boolean
Dim bRebuild            As Boolean
Sub Main()
    Set swModel = swApp.ActiveDoc
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
FilePath = swModel.GetPathName()
PathSize = Strings.Len(FilePath)
PathNoExtension = Strings.Left(FilePath, PathSize - 6)
NewFilePath = PathNoExtension + sConfigName & ".DWG"
    Set swPart = swApp.NewDocument("Z:\Solidworks\Current\templates\CBC B SIZE.drwdot", 0, 0, 0)
    Set swView = swPart.CreateDrawViewFromModelView3(NewFilePath, "*Right", 0, 0, 0)
    bView = swPart.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
    bView = swPart.ActivateView("Drawing View1")
    bView = swPart.ActivateSheet("Sheet1")
    vConfs = swModel.GetConfigurationNames()
    For i = 0 To UBound(vConfs)
        sConfigName = vConfs(i)
        bView = swPart.ChangeRefConfigurationOfFlatPatternView(NewFilePath, sConfigName)
        bRebuild = swModel.ForceRebuild3(False)
    Next i
