Again I'm having a problem, but in this case I've never seen this before or know how to fix it. I'm trying to do a regular straight cut extrude through my part and it is making odd points were it shouldn't or I couldn't cut everything because the program gives me an error saying it will result in zero thickness. The picture and model show what I can cut, but the pattern should be the same throughout the part which it isn't letting me do. I've made similar parts like this before and never had this occur in any of them. Does anyone have an idea on how to fix it? Thank you for the help and if there is anything else you need from me please let me know.
If you do a check prior to the cut it shows an error. Could be the problem.
