19 Replies Latest reply on Feb 14, 2018 2:56 PM by Sergey Kolesnik
    GetAnnotationCount
    Sergey Kolesnik
      Hi there. Can anybody tell me if there is a GetAnnotationCount method for Drawing Document, not an IVew member? IModelDocExtention member is for parts only, as it seems. It returns zero for drawing.
      Using IVeiw can return total number of annotations in the document by traversing all the views, but still there may be (and usually there are some) annotations on sheet layer, not hosted by any view.
      I have a thought about some workaround such as traversing with IView::GetFirstAnnotation3 (still what if there are no views at all?) and IAnnotation::GetNext3 while GetNext3 succeeds (not sure though).
      Any advice on situation? Or maybe there's a way to return an array of all the annotations in the drawing doc? =)
      Update:
      I've tried traversing Annotations with for loop. But it seems that GetNext3 returns pointers only for Balloons, though it should return for other type regardless since Annotation is a common class.
      There are definetely more than 3 annotations. I added third balloon and another exception was thrown after i = 2. For 2 balloons it was i = 1 and exception. Though, exception after i = 2 when it actually was to stop iterating, is a question of a special interest, why doesn't it return another types of annotations??
      Сообщение отредактировано: Sergey Kolesnik
        • Re: GetAnnotationCount
          Jacob Corder
          the ISheet:FirstView actually returns the Sheet as a view.  so
          2018 SOLIDWORKS API Help - GetFirstView Method (IDrawingDoc)
          i have not found a way to get the Sheet As a view from an inactive sheet.  the only way i can find how to do that is to activate it.  i will keep looking. i have tried
          casting from ISheet
          casting from IFeature.GetSpecificFeature2 (Retrieved from DDOC.GetFeatureByName(SHeetName))
          maybe someone else knows a way to get the sheet as a view from an inactive sheet.
              Sergey Kolesnik
              Sheet as a View? How's that?)) It definetely says of returning a pointer to the first view in the document.
              Actually, there's another question which I'll add to the main. That is, GetNext3 is to return IAnnotation object. And Annotation is a common class for Notes, Dimensions, etc. But I actually can get only those of Balloons. Why so?
                  Josh Brady
                  Read the help.  It's stated pretty clearly that GetFirstView returns the sheet.
                  You have not posted your code, therefore we cannot find your mistake.
                      Sergey Kolesnik
                      Clear as it is.
                      CComPtr<IView> pView;
                      pDrawing->IGetFirstView(&pView);
                      CComPtr<IAnnotation> pAnnF;
                      CComPtr<IAnnotation> pAnnS;
                      pView->GetFirstAnnotation3(&pAnnF);
                      long anType = 0;
                      BSTR anName;
                      double XY;
                      pAnnF->GetType(&anType);
                      pAnnF->GetName(&anName);
                      pAnnF->IGetPosition(&XY);
                      std::cout << "Annotation type num: " << anType << " , Name: " << anName
                      << " , Position XY: " << XY << std::endl;
                      for (int i = 1; i != 3; ++i)
                      pAnnF->GetNext3(&pAnnS);
                      pAnnS->GetType(&anType);
                      pAnnS->GetName(&anName);
                      pAnnS->IGetPosition(&XY);
                          Jacob Corder
                          in C++ can you execute a while loop?
                          because in vb you write this
                          Do until PAnnF is nothing
                              Do your stuff here
                              pAnnF = PAnnF.GetNext
                          loop
                          like this
                          and i am only guessing here so go easy on me.
                          do-while Statement (C++)
                          long anType = 0;
                          BSTR anName;
                          double XY;
                          do
                            } while pAnns 1= null
                            Josh Brady
                            I don't C, but looks like your problem is at the end of the loop.  It goes back to the beginning to pAnnF again to get next annotation.  During loop, you need to get next annotation from previous one.  You can't get from the first one.
                            Sergey Kolesnik
                            Now I've noticed. You're talking about GetFirstView, not IGetFirstView. There's a remark for actually returning the sheet.
                                Josh Brady
                                Help for both is identical.  You have to read the whole thing.  Be thorough.  Part of competence.
                                Please study this macro.  Again, it's VBA vs C whatever, but it returns all annotation types.
                                Dim swDoc As SldWorks.ModelDoc2
                                Dim swExt As SldWorks.ModelDocExtension
                                Dim swDwg As SldWorks.DrawingDoc
                                Dim swSht As SldWorks.Sheet
                                Dim swView As SldWorks.View
                                Dim swAnnot As SldWorks.Annotation
                                Dim i As Long
                                Set swDoc = swApp.ActiveDoc
                                Set swExt = swDoc.Extension
                                Set swDwg = swDoc
                                Set swSht = swDwg.GetCurrentSheet
                                Set swView = swDwg.GetFirstView
                                Debug.Print "Annots: " & swExt.GetAnnotationCount
                                While Not swView Is Nothing
                                    Debug.Print swView.Name
                                    Debug.Print "view annots: " & swView.GetAnnotationCount
                                    Set swAnnot = swView.GetFirstAnnotation3
                                    i = 1
                                    While Not swAnnot Is Nothing
                                        Debug.Print , "Annotation " & i & ":", "Type: " & swAnnot.GetType, "Name: " & swAnnot.GetName
                                        Set swAnnot = swAnnot.GetNext3
                                        i = i + 1
                                    Wend
                                    Set swView = swView.GetNextView
                                Wend
                                    Sergey Kolesnik
                                    What you suggested ended up with exception, but!
                                    This way there's no exception. But while loop still gets no more than 1 iteration(( 57 annotations total (I can barely see 15-20) returned. Not to mention that its value doesn't change if I remove any from drawing.
                                        Jacob Corder
                                        your not getting any because pAnnS has never been assigned a value before the while loop
                                        delete the variable pAnnS.
                                        change everywhere pAnnS is used to pAnnF
                                        pAnnF->GetNext3(&pAnnF);
                                        move the pAnnF->GetNext3(&pAnnF) to before std::cout
                                        while (pAnnF == s_Ok)
                                        pAnnF->GetName(&AnName);
                                        std::cout
