Macro won't work unless opened/closed first.
Question asked by Matt Zellmer on Feb 13, 2018
Latest reply on Feb 13, 2018 by Matt Zellmer
I have a macro I created that saves a drawing as a PDF with the Revision added on the end.  It works fine but will only work if I first open it in the VBA editor then close it (not even saving or touching anything), then it runs just fine.  Any help is appreciated.  Below is the macro:
Option Explicit
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim PDFFileName     As String
Dim PDFPath         As String
Dim Revision        As String
Sub Main()
Set swModel = swApp.ActiveDoc
'Get Revision
Revision = swModel.CustomInfo("Revision")
'Set Path
PDFPath = PDFPath & "C:\Users\mzellmer\Desktop\MZ\Temp"
'Set File Name
PDFFileName = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
PDFFileName = Left(PDFFileName, InStrRev(PDFFileName, ".") - 1) & " Rev_" & Revision & ".PDF"
'Save File
swModel.SaveAs (PDFPath & "\" & PDFFileName)
