Part number help. Need to create a changing serial number
Question asked by Justin Phillips on Feb 13, 2018
Latest reply on Feb 13, 2018 by David Matula
I need to create a quick way to change out " serial" sequence numbers and I am at a standstill. I need to change out 3 font sequences with a different part number on different parts. These all will be one off laser cut sheet metal parts. Right now, I am sketching the " stencil" in, extrude cutting and  then saving. then renaming every single line, and then saving as... Its extremely time consuming. I am spending more time programming than the actual laser cut time. Can anyone point me to do this where I could just type int he number and it would convert all 3 areas ( 2 normal, 1 upside down and mirrored?) see below? The part numbers will change as well as the width ( based on how many part numbers).
Any help is very appreciated. Thanks!
