I would like to make several cuts in a sheet metal part after the part has been bent up (they are too close to where the bends are). Is there any way to exclude these cuts from the part's flat pattern? (Since they wouldn't exist at that time and I don't want the sheet blank cut out to have them)
Hey Otis,
You can try making a new configuration for your part with these hole suppressed. That way you have a configuration for both pre and post hole cut operation.
Ben
