I've had this happen several times now; I create a belt
feature, and SW complains saying that the pulley's are fixed. But,
I have unchecked the check box to have the belt size drive the
pulley position. I.e. the pulley's are all fixed and I want the
belt to adjust to fit the pulleys.
I called my dealer, and was preparing to show him the error, so I right-clicked the belt feature and choose to edit it. Then, I escaped out of it, without any changes. The error disappeared. Note that I have made several such attempts before, trying to force SW to re-evaluate the belt. I also tried checking the box to have it rebuild that way, and then re-editing the feature and unchecking the box. I also tried the standard Cntl-Q.
When this problem first appeared, and I couldn't resolve it, I decided to just recreate the belt, but that didn't stop the problem. It looks like most of the time, SW was ignoring that this check box was unchecked.
Anyone else having problems with belts?
I dont remember how I repaired it finally or if it went away.In my case though I had one pulley that wasnt fully fixed.
I wasnt sure what I was doing wrong at the time but I guess reading your post now there has to be a bug in there..which is comforting to both of us. I would report the issue even if you cant recreate it cos belts are important to some users
BTW there seemed to be update issues with using the belt thickness or not too now that I think about it
