Trying to create a sheet metal part. I created my 2 inside and outside profiles, but I can't select them for the Lofted Bends.
The thickness is 10ga (.134)
Any help? Thanks.
Switch on formed method, create two 3D sketches, one for each helix
..as Igor said,.. you will need to make (2) 3dsketches (image attached)
Why you`ve closed them?It is not necessary.
hmm?.. the orange boundary is a preview of the Loft using the (2) 3dsketches,.. nothing is closed.
Your preview looks different than mine
Hello Igor,.. yes, my "Shaded Preview" setting is turned Off. (image attached)
I thought as much
Please, look this help with auger flat pattern also
