2 Replies Latest reply on Feb 13, 2018 10:32 AM by Michael Rauter
    Move and rotate component
    Michael Rauter
      I am in desperate need of some help with a portion of a macro that is supposed to rotate a part.
      I (macro) recorded the necessary step and ended up with the code below.
      Even with my limited programming skills I recodnice SW seems to control rotation and movement with the array TransformData()
      Controlling regular movement in x, y and z is easy enough:
      You just need to put the value / 1000 in vTransformData(9), vTransformData(10), vTransformData(11)
      Rotation is the problem:
      TransformData(0 to 8) needs to be filled with values between -1 and 1. But it seems impossible to me get to them from regular angles [°].
      Troughs the process of elimination I ended up with the following calculation. It seems to work well enough with most angles. But when one of the angles is 90° (etc.) you get a multiplication with 0. But you don’t get 0 when you (macro) record the same rotation.
      vTransformData(0) = COS(Y/180*PI) * COS(Z/180*PI)
      vTransformData(1) = COS(X/180*PI) * SIN(Z/180*PI) <<
      vTransformData(2) = SIN(Z/180*PI) * SIN(X/180*PI) <<
      vTransformData(3) = -COS(Y/180*PI) * SIN(Z/180*PI)
      vTransformData(4) = COS(Z/180*PI) * COS(X/180*PI) <<
      vTransformData(5) = COS(Z/180*PI) * SIN(X/180*PI) <<
      vTransformData(6) = SIN(Y/180*PI)
      vTransformData(7) = -SIN(X/180*PI) * COS(Y/180*PI)
      vTransformData(8) = COS(X/180*PI) * COS(Y/180*PI)
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Point1@Ursprung", "EXTSKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0)
      boolstatus = Part.Extension.SelectByID2("Modell-9@Baugruppe1", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
      Part.ClearSelection2 True
      Dim TransformData() As Double
      ReDim TransformData(0 To 15) As Double
      TransformData(0) = 0
      TransformData(1) = 1
      TransformData(2) = 0
      TransformData(3) = -1
      TransformData(4) = 0
      TransformData(5) = 0
      TransformData(6) = 0
      TransformData(7) = 0
      TransformData(8) = 1
      TransformData(9) = 0
      TransformData(10) = 0
      TransformData(11) = 0
      TransformData(12) = 1
      TransformData(13) = 0
      TransformData(14) = 0
      TransformData(15) = 0
      Dim TransformDataVariant As Variant
      TransformDataVariant = TransformData
      Dim swMathUtil As Object
      Set swMathUtil = swApp.GetMathUtility()
      Dim swTransform As Object
      Set swTransform = swMathUtil.CreateTransform((TransformDataVariant))
      Dim swComp As Object
      Set swComp = Part.SelectionManager.GetSelectedObjectsComponent4(1, -1)
      boolstatus = swComp.SetTransformAndSolve2(swTransform)
      boolstatus = Part.ForceRebuild3(False)
        • Re: Move and rotate component
          Ivana Kolin
          Option Explicit
          Const PI                As Double = 3.14159
          Const RadPerDeg         As Double = PI / 180#
              Dim swModel As ModelDoc2
              Dim swAssy As AssemblyDoc
              Dim swComp As Component2
              Dim vComponents As Variant
              Dim swTransform As MathTransform
              Dim swRotTransform As MathTransform
              Dim nPts(2) As Double
              Dim vData As Variant
              Dim swOriginPt As SldWorks.MathPoint
              Dim swX_Axis As SldWorks.MathVector
              Set swModel = swApp.ActiveDoc
              swModel.ClearSelection2 True
              Set swAssy = swModel
              vComponents = swAssy.GetComponents(True)
              Set swComp = vComponents(0)
              Set swTransform = swComp.Transform2
              Dim swMathUtil As MathUtility
              nPts(0) = swTransform.ArrayData(9)
              nPts(1) = swTransform.ArrayData(10)
              nPts(2) = swTransform.ArrayData(11)
              vData = nPts
              Set swOriginPt = swMathUtil.CreatePoint(vData)
              nPts(0) = swTransform.ArrayData(0)
              nPts(1) = swTransform.ArrayData(1)
              nPts(2) = swTransform.ArrayData(2)
              vData = nPts
              Set swX_Axis = swMathUtil.CreateVector(vData)
              Set swRotTransform = swMathUtil.CreateTransformRotateAxis(swOriginPt, swX_Axis, 10# * RadPerDeg)
              Set swTransform = swTransform.Multiply(swRotTransform)
              boolstatus = swModel.ForceRebuild3(False)
