I have a part that has several lines of text actually painted on its surface. What is the best way to depict this? I am not looking for extruded or embossed text. I can not use a decal as that would be included in the BOM. Each line of text is a specific height and there is specific line spacing requirements between lines.
Doesn't paint have an actual thickness?
If you don't want to add a thickness for the paint you could Split the face(s) and change the Face Appearance(s).
Attach your *.sldprt file here if you can't figure it out.
