Replace Note With Macro
Question asked by Gaurav Bhonsule on Feb 10, 2018
Latest reply on Feb 11, 2018 by Gaurav Bhonsule
Hello All,
I have recorded below macro & make minor changes.
Code work well and change the Note "ABC" to "DEF"
1- Now I want to extend this code through all sheets
I have tried to extend this code to use for all sheets but it work for active sheet only.
2-  All Sheet have Note "123" which I want to delete .
Please put some light on this.
' macro recorded on 02/08/18 by Gaurav
Dim swApp As Object
Dim Part As Object
Dim swModel     As SldWorks.ModelDoc2
Dim swDraw      As SldWorks.DrawingDoc
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
'boolstatus = Part.Extension.SelectByID2("Template", "SHEET", 0.2161171875, 0.2239453125, 0, False, 0, Nothing, 0)
'--------------------Find and Replace Annotations--------------------
Set swUtil = swApp.GetAddInObject("Utilities.UtilitiesApp")
Set swUtilFindReplaceAnnotations = swUtil.FindReplaceAnnotations
longstatus = swUtilFindReplaceAnnotations.InitPMPage()
'--------------------Block Recording--------------------
#If 0 Then
#End If
'--------------------UnBlock Recording------------------
swUtilFindReplaceAnnotations.FindText = "ABC"
swUtilFindReplaceAnnotations.ReplaceText = "DEF"
swUtilFindReplaceAnnotations.Options = gtFraWholeWord
swUtilFindReplaceAnnotations.AnnotationFilter = gtFraNote
Part.ClearSelection2 True
longstatus = swUtilFindReplaceAnnotations.ReplaceAll()
#If 0 Then
#End If
longstatus = swUtilFindReplaceAnnotations.Close()
'boolstatus = Part.Extension.SelectByID2("Template", "SHEET", 0.2440078125, 0.090628125, 0, False, 0, Nothing, 0)
Regards,
Gaurav
