Can't perform sweep cut.
It is on two separate 3d sketch
It will be easier if you can post your part or let us know what the error message is & someone will be able to help I'm sure.
Forum Posting
Some very important steps if you are a NEW FORUM USER....
if converted as a single sketch - The profile must be different from the path
separate sketch - is selt intersecting or the section profile is a closed nonplanar 3d sketch is not allowed
using other edges as guide curve still doesn't s work
how to I attached a part. Only allows pics
top right of new post window....
"Use advanced editor"
here is the part file
Can somebody please help
Hi Chung:
I used a different approach, probably not the best one.
..you could also do a surface loft/boundary diagonal edges.. and extend the perimeter.. and cut..
Yes I know I could but would like to know why the sweep boss function doesn't work.
I'd rather not have to use surfaces if it can be avoided.
but I do appreciate you helping me out.
I think the sweep cut feature not working is because of the " zero-thickness geometry" issue.
Forum Posting
