I want to make this model split into two parts but split command is making it three parts. I do not want body 1 to be spited.
Is it possible to do?
Maha,
Create an Extruded surface using your Sketch line & split with that instead.
Or you can still split into three solid bodies using the Sketch line & Combine two of them again.
Thanks for the explanation.
What you do is select what cut to make and it will not make make the third body
Thanks for alternative method.
I would think it would be the preferred since it is one less feature?
Maha,
