Hi guys,
When I did a search that contains " it will give me the below result.
The question is $PRP:"SW-File Name" is not shown in the data card under part number variable.
And if i want to make part number variable a unique values, it will show me the below screenshot. It should show me the files that have unique values but there are nothing displayed.
This is really puzzling. Do you guys face such problem before?
Can you verify that it's not in any of the configuration tabs on the datacard as well? You can dig deeper into this by creating a DWORD in HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise named DebugSql and setting it to 1, then creating a txt directly under the C:\ drive name Search.txt and it will give you the search query it ran that you can paste into SQL Server Management Studio and then checking the results for more clues.
