Re: Bug in SW2018?: Document not accessible after deleting Exploded Step
Jim Wilkinson Feb 8, 2018 12:20 PM (in response to Egbert Joostens)Hi Egbert,
That is an interesting one. The problem actually only occurs if you have the component selected in the graphics area when you choose the Delete Explode Step option. This is already logged as SPR# 1051261. You can either report it to your reseller asking to be attached to that SPR or go to the knowledge base, search for that number, and then choose the option on the left to notify you when the issue is fixed. Please do one of these two things since it will add a hit to the SPR, therefore elevating the priority. This link *may* take you directly to the knowledge base article directly depending on if the URL passes through the login without issues:Thanks,
Jim
Egbert Joostens Feb 8, 2018 12:39 PM (in response to Jim Wilkinson)Thanks Jim, good to know the problem is already logged!
Jim Wilkinson May 29, 2018 6:18 AM (in response to Egbert Joostens)Hi Egbert,
This problem has been fixed in SOLIDWORKS 2018 SP03 which is now available for download.
Jim
