Hi Team,
I have an issue when I try to edit a sketch of one of the 3D extrusions, that all the previous Solid bodies and extrusions disappear. What makes it even stranger is that it only happens when I open edit sketch on one particular extrusion.
When I edit sketch in this extrusion, all preceding bodies remain
When I do it on this extrusion, all disappear
Does anyone know what could be causing this?
It is most likely because that sketch was created before any of the extrusions. Thus, when you edit it, the model tree is "rolled back" to when the sketch was created.
Here is an example.
Notice that Sketch2 was created after Extrude1, and before the hole wizard features and fillet features.
After creating those features, I click on Sketch2 and click on Extruded Cut...creating a blind cut (Cut-Extrude1).
Notice that Sketch2 is now at the bottom of the tree...
If I edit that sketch, this is what it looks like...
The model rolls back to the point in the tree when the sketch was created.
