When l try to "Show Wire Marks" I get a message: Cannot run "Show/hide wire marks". Selection does not include the following data: "Equipotential mark".
The wires are terminated on one end by a BNC connector and other end on a terminal. The wires are attached to a connection point.
What am I doing wrong?
Have you generated a equipotential mark for the wire using Process>Number New Wires? Right click the wire and select: Equipotential Properties. If the value for "Mark" is blank you will receive this error.
