How to Remove the original Revolved Cut location when Sketch Pattern is used?
Question asked by Shuhei Kazuma on Feb 6, 2018
Latest reply on Feb 6, 2018 by Shuhei Kazuma
Hi experts,
I am using combination of 2 sketches to distribute custom hole over points on sketch
1. POINT_LOCATIONS sketch determines where the holes should be
2. HOLE_SHAPE determines the shape of the sketch. Then make Revolved cut to fully determine the hole shape.
3. Use Sketch-Pattern feature to distribute the defined hole over the points on the POINT_LOCATIONS..
Problem I want to solve:
I do not need the original hole defined in the 'HOLE_DEF'. But this must exist for the sketch-pattern to work.
I suppressed it but then Sketch-Pattern feature gets suppressed too.
