Hi everyone,
I'm trying to do a detail drawing of a layout, but everytime i try to use a depth section view the result "hides" some parts. I'll attach some pictures to help the understanding.
Hi everyone,
Hi, thanks for your answer.
The thing is that i'm not trying to show a section of a part, i'm trying to show just a section from a very big layout. There's lots of equipments there, and i'm trying to show how only one line of them looks, therefore i need the section with depth, otherwise it will show my whole layout which is not alligned and will look very messy (The two locations we have to show aren't alligned).
I just don't get what you mean. I don't believe the error is in my assembly, i think there's something about the drawing. I can show everything in the section perfectly, but when i try to use the depth it just hides everything lower than the roof
Showing everything, even lower than the roof
When i try to use the depth function it just hides everything. Even though it clearly should be showing as you can see in the depth line.
OK, as I understood you don`t understand me when I wrote about creating of section in assemly.
So, to find out what bodies cause the error I suggested to make the same section in assembly file.
Now, about section depth, as workaround you can create display state special for this section. In this display state you hide all bodies behind your depth line.
No, display state is display state, section view is section view.
I wrote about section view because it is a fast preliminary way to find out some problems with sectioning of your assembly in drawing.
You lost a lot of time in your drawing if will try to find problem bodies in it.
Now about display state: if you don`t find problem bodies you must create display state in assembly and use it for section view without depth option.
Increase the depth a little bit
