Re: how do I export with joined polylines
Bob Van Dick Feb 6, 2018 9:54 AM (in response to Greg McMurry)Greg,
I have always wondered the same thing. It hard on the laser when you have segments that get down into the .001 lengths. You mentioned you use autocad to join them. Does it join all the segments into one continuous profile or just make them longer segments? I don't use or have autocad, however, I know somebody that does. How do you go about "joining" them in autocad?
Bob
Greg McMurry Feb 6, 2018 10:28 AM (in response to Bob Van Dick)In AC you just highlight the whole DXF (ctl A) then click on the "join lines" in the Modify pulldown. Then resave the DXF.
When you first load the SW generated DXF, put your cursor on what appears to be a continuous line. It probably is not. If the entire line does not highlight, then do the above and try it again.
I use Torchmate CAD to path my projects that we make on a plasma cutter. I have to do this every time. I don't have an AC license on the same machine I have SW on nor on the machine I have Torchmate CAD so it is always an extra step.
Greg
Bob Van Dick Feb 6, 2018 10:38 AM (in response to Greg McMurry)Thanks for the info!
Bob
