Does anyone know of a quick way to slice a part into layers? I need to slice a part so I can cut it out of sheet metal and then stack it together. I wish there was a tool like 123d slicer in Solidworks, but I haven't found it if their is. I know how to slice a part using planes or surfaced. The problem is that I will end up with over 450 layers. I would really like to not have to manually go in and number each one and create a dxf cut file for each one. Any ideas?
What you're describing is very similar to what a slicer program does with a solid model to prepare it for use by a 3D printer. Perhaps you could look for a slicer program that allows the exportation of slices as .dxf files...?
