this is my simplified code and the problem is with assemblies:
Dim thisConfig As SldWorks.Configuration
Dim ConfigNames As Variant
Dim KonfigName As String
Dim value As Boolean
Dim i As Integer
Private Sub CommandButton1_Click()
Set swModel = swApp.ActiveDoc
ConfigCount = swModel.GetConfigurationCount
ConfigNames = swModel.GetConfigurationNames
For i = 0 To (ConfigCount - 1)
KonfigName = ConfigNames(i)
Set thisConfig = swModel.GetConfigurationByName(KonfigName)
If CheckBox3.value = True Then
thisConfig.HideNewComponentModels = True
Else
thisConfig.HideNewComponentModels = False
Next i
value = swModel.EditRebuild3()
If thisConfig.HideNewComponentModels is set to True, then the checkmark is set correctly.
You can see this in the Properties of Display State Properties.
If thisConfig.HideNewComponentModels is set to False, the checkmark will not be reset.
Why, is this a Bug?
Greetings, Andi
