1 Reply Latest reply on Feb 4, 2009 4:08 PM by Mark Kaiser
    Drawing Troubles
    Mark Clifft
      I've created new drawings from existing drawings using the save as a copy function. The new slddrw, sldasm & sldprt are created, modified & printed then closed. When I now open these new files the sldprt & sldasm files are correct but the slddrw files are a hodgepodge of lines and dimensions of both the new part and the old existing part from which it was created. The only fix I've found is to go back and edit part and assembly then rebuild. This never happened in 2008. Is there a fix or do I have a setting wrong? SW 2009 sp2 ~ winxp
