I was trying to bring table to parallel plane without success.
As I understand, to do this now it is necessary to recreate table or annotation. Copying and pasting of table or annotation works for placement on a face (not on a plane) only.
Moreover, the original table is even not in the Front plane
Hi Igor,
I only really do tables in drawings so I have no direct answer to what you are asking. But could you not just move the parts closer to the BOM/Top plane? Also, if you used a linear pattern then changed the config on the last instance, you'd have them all fully constrained and aligned without further constraints being required.
