how to save sheets separately to pdf in vba
Question asked by Hank Costner on Feb 1, 2018
Latest reply on Feb 8, 2018 by Hank Costner
I am using code that I found on this forum. I program in C++ normally. I'm learning how to work with SolidWorks VBA. I want to take a drawing file with many sheets (the amount will always be in multiples of 3) and save one sheet by itself, then the next two together. That process would be repeated until all the sheets are saved. When I run the program on a drawing file consisting of 3 sheets, it makes 2 pdf files (as expected). However, both pdf files have all 3 sheets. One pdf file should have one sheet, and the other should have two sheets.
I'm using this line to set the sheets to be saved ==> swExportPDFData.SetSheets swExportData_ExportSpecifiedSheets, sales
sales is an array that holds one sheet name.
As far as I know, swExportData_ExportSpecifiedSheets tells the computer that I'm saving sheets separately.
This line is in context below. The complete code is further below.
line in context
vSheetNameArr = swDraw.GetSheetNames
Dim numberOfSheets As Integer
numberOfSheets = swModel.GetSheetCount
Dim i As Integer
i = 0
Dim sales(0) As Variant
Dim fab(1) As Variant
MsgBox vSheetNameArr(0)
Set swExportPDFData = swApp.GetExportFileData(1)
Do While i < numberOfSheets
sales(0) = vSheetNameArr(i)
fab(0) = vSheetNameArr(i + 1)
fab(1) = vSheetNameArr(i + 2)
swModel.Extension.SaveAs Path & sales(0) & ".PDF", 0, 0, swExportPDFData, lErrors, lWarnings
swExportPDFData.SetSheets swExportData_ExportSpecifiedSheets, fab
swModel.Extension.SaveAs Path & fab(0) & " & QC " & ".PDF", 0, 0, swExportPDFData, lErrors, lWarnings
i = i + 3
Loop
complete code
' This macro is provided as is.  No claims, support, refund, safety net, or
' warranties are expressed or implied.  By using this macro and/or its code in
' any way whatsoever, the user and any entities which the user represents,
' agree to hold the authors free of any and all liability.  Free distribution
' and use of this code in other free works is welcome.  If any portion of
' this code is used in other works, credit to the authors must be placed in
' that work within a user viewable location (e.g., macro header).  All other
' forms of distribution (i.e., not free, fee for delivery, etc) are prohibited
' without the expressed written consent by the authors.  Use at your own risk!
' Written by: Deepak Gupta (http://gupta9665.com/)
' Version 2: Added option for selecting Output folder ------------- 08/07/14
' Version 2.1: Added revision in file name ------------- 01/20/15
Option Explicit
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Function BrowseFolder(Optional Caption As String, _
    Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.Folder
Set SH = New Shell32.Shell
Set F = SH.BrowseForFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder = "Desktop")
If Not F Is Nothing Then
    BrowseFolder = F.Items.Item.Path
End Function
Dim swApp                   As SldWorks.SldWorks
Dim swModel                 As SldWorks.ModelDoc2
Dim swDraw                  As SldWorks.DrawingDoc
Dim swSheet                 As SldWorks.Sheet
Dim vSheetNameArr           As Variant
Dim vSheetName              As Variant
Dim bRet                    As Boolean
Dim swExportPDFData         As SldWorks.IExportPdfData
Dim lErrors                 As Long
Dim lWarnings               As Long
Dim Path                    As String
Dim Value                   As String
    Path = BrowseFolder("Select a Path/Folder")
    If Path = "" Then
    MsgBox "Please select the path and try again"
    End
    Else
    Path = Path & "\"
Set swModel = swApp.ActiveDoc
' Is document active?
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "A Drawing document must be active.", swMbWarning, swMbOk
    Exit Sub
' Is it a Drawing document?
If swModel.GetType <> swDocDRAWING Then
    Exit Sub
Set swDraw = swModel
Value = swDraw.CustomInfo("Revision")
Set swSheet = swDraw.GetCurrentSheet
Dim i As Integer
i = 0
i = i + 3
Loop
