I regularly create a sketch in the top plane and insert a sketch picture, but the location of the sketch picture is different every time. Is there a way to run a macro that takes me to the Open dialogue so I can navigate to the image myself?
This macro inserts the same image every time.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Top Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.SketchManager.InsertSketch True
Dim SkPicture As Object
Set SkPicture = Part.SketchManager.InsertSketchPicture("File Location")
What can I change so it lets me choose what image to open?
Thank you
Hi Liam
This should help
2016 SOLIDWORKS API Help - Open File Example (VBA)
