Solidworks API: Integer not an Integer?
Question asked by John Boire on Feb 1, 2018
Latest reply on Feb 1, 2018 by John Boire
So here is something interesting,
I wrote a quick function to split a number up, nothing fancy:
Function GetDocNumbers(ConfigNum As Integer) As Variant()
    If ConfigNum > 48 Then
        GetDocNumbers = Array(0, 0, 0)
Dim tens, remainder, split, i As Integer
tens = ConfigNum / 10
remainder = ConfigNum Mod 10
    If remainder > 0 Then
        split = remainder / tens
        i = remainder Mod tens
'Return in an array (Number of Documents, Number of sheets per Document, Leftovers(for uneven numbers)
    If tens = 1 And remainder <= 4 Then
        GetDocNumbers = Array(1, ConfigNum, 0)
    ElseIf tens = 1 And remainder > 4 Then
        GetDocNumbers = Array(2, ConfigNum / 2, i)
    Else
        GetDocNumbers = Array(tens, 10 + split, i)
Debug.Print ("GetDocNumbers Run: Success")
End Function
The function runs, however when I put in 22, expecting to get the result
(2,11,0)
I get (2.2, 10.909ect, 0)
Any idea why?
Is there another data type I need to use? Do I not know what an integer is?
