Hi all
Hopefully someone can help with this. Up until now i have always worked from one pc and not using networked files. i now work somewhere where there are approx 4 users (no PDM system) their setup is that they have created a library of parts and subassemblies with configurations in folders on the network.
when you make an assembly you obviously bring in each part or subassembly as make the full assembly.
this is fine until i wanted to change one subassembly configuration in my assembly to a different length for example. a co-worked then opened his assembly that has the same subassembly referenced part in it and it had changed his part to my configuration.
what we don't want is multiple copies of parts or subassemblies. what am i doing wrong or should we be using PDM?
many thanks
Kevin gray
Well PDM would give you more control over data management so I would vouch for it. And from your current situation, it looks like that you accidentally changed the length for all configurations instead of one. make sure that you select "This configuration" when making the changes.
