Re: "make horizontal" Automatically
Glenn Schroeder Jan 30, 2018 8:07 AM (in response to Jos Veurink)Unfortunately, that's one of those "inferred relations" that doesn't actually create a relation. You can of course go back and apply the relation, but what I often do in cases like that is add a construction line, that will snap to horizontal, and make the second circle's centerpoint coincident with the end of the line.
Jos Veurink Jan 30, 2018 8:29 AM (in response to Glenn Schroeder)It looks indeed thats just an "information line" to indicate thats horinzontal with the orde hole.
a construction line is a option.
Thanks!
Steve Calvert Jan 30, 2018 8:33 AM (in response to Jos Veurink)I tend to use a construction line because it's easy to see and easier for others to comprehend.
Steve C
Britt Kessler Jan 30, 2018 12:27 PM (in response to Glenn Schroeder)Glenn Schroeder wrote:
"Unfortunately, that's one of those "inferred relations" that doesn't actually create a relation. You can of course go back and apply the relation, but what I often do in cases like that is add a construction line, that will snap to horizontal, and make the second circle's centerpoint coincident with the end of the line."
I was playing with the inferred relations, and I tried using the "H" hot key to create a relation, but it does not seem to activate? Aren't the underlined letters supposed to activate the relation, just like it would when you actually mouse over and click the button?
Colt Carson Jan 30, 2018 12:44 PM (in response to Britt Kessler)Britt Kessler wrote:
You have to hit alt key then the letter H
Britt Kessler Jan 30, 2018 1:14 PM (in response to Colt Carson)Somewhat cumbersome, which is probably why I haven't used it... If you still have the Ctrl button pressed the operation will not complete.
Igor Fomenko Jan 30, 2018 12:37 PM (in response to Jos Veurink)Write enhancement request - it`ll be inverse function for cntr which switch off snapping
