Hi There
I have created a model and made a drawing from this but I had to hide a component for a customer, so I saved this model with this change to update my drawing but how to o get it back on the model?
Hi There
If you just hide the component, you can show it with many ways.
Using the FeatureManager, the hide component is showed colorless.
You can click right mouse button and select option 'Show components'.
If you supresses the component, it is showed grayed out.
You can click right mouse button and choose the option 'Unsupress'
From your description it sounds like you opened an Assembly, hid a component, and now want to show it again. I assume it's difficult to find because it may be hidden in a feature or folder. If that's the case, it's a pretty easy fix. Right-click on the file name at the top of the tree and choose "Show with Dependents". That will un-hide any hidden components.
Are you talking about hiding a component in the assembly? Just un-hide it of if it's suppressed, just un-suppress it.
Are you talking about features on a model? Just un-suppress it.
HTH
Steve C
