How to get ActiveDoc in EnableMethod(string s) of CommandItem
Question asked by Dennis Beeren on Jan 30, 2018
Latest reply on Jan 30, 2018 by Dennis Beeren
I would like to set the enable setting of a command item (toolbar button) based on the parameter s and the active doc type (swDocumentTypes_e), but I am not able to get the active doc in the EnableMethod. This Method is in the class implementing ISwAddin. Here's the code of my EnableMethod():
         * Called before loading command item
         * to determine if this command item has to
         * be enabled for the current document type.
         * @param s: 1 -> parts | 2 -> assemblies | 3 -> parts & assemblies |
         *           4 -> drawings | 5 -> parts & drawings | 6 -> assemblies & drawings
         *           7 -> parts & assemblies & drawings
        public int EnableMethod(string s)
            ModelDoc2 model = mySWApp.ActiveDoc();
            if (model != null)
                int docType = model.GetType();
                int i = int.Parse(s);
                if (docType == (int)swDocumentTypes_e.swDocPART && (i == 1 || i == 3 || i == 5 || i == 7))
                    return 1;
                else if (docType == (int)swDocumentTypes_e.swDocASSEMBLY && (i == 2 || i == 3 || i == 6 || i == 7))
                    return 1;
                else if ((docType == (int)swDocumentTypes_e.swDocASSEMBLY && i > 3))
                    return 1;
                else
                    return 0;
            else
                return 0;
I wonder what I am doing wrong here and what would be a way to do this. I would like to determine for each command item if it should be enabled, based on the document type. Any help is appreciated.
