0 Replies Latest reply on Jan 29, 2018 1:13 PM by Jean-Marc Langlois
    Degree 1 bspline curves in SolidWorks 2018
    Jean-Marc Langlois
      Hi all,
      I have implemented a while ago some code that creates bspline curves in SolidWorks 2015 up to 2017 and that has been working correctly ever since. I also had to write code that created polylines, and I ended up creating these polylines as degree 1 bspline curves. That also worked as expected.
      Now I am trying to run the same code against SolidWorks 2018 and I can no longer create degree 1 bspline curves, I am systematically getting an exception upon calling "CreateSplinesByEqnParams2", while with the same bspline data/values, this works nicely in SolidWorks 2015.
      So 2 questions here:
      1) Has anything changed in SolidWork 2018 that would explain this regression ?
      2) Is there another way of creating a polyline using the API in SolidWorks. Of course, one can create line instances for each segment of the polyline, but in the end what we end up with a a bunch of individual lines in a sketch, which is not what we want. Also this tends to be much slower than creating a degree 1 curve.
      Attached is a C# test project that reproduces the issue if executed against 2018, and that works ok if executed against SW 2015
      Any comment will be much appreciated
      Regards
      JM Langlois
