hi ,
when i try to right click on the results folder in SWX Simulation-2009 and try to go for the "define design scenario graph" i am not getting it what is the reason. also the study is run and graphs are defined when i open them it says "database not found" why is that?
also this is one of the lessons on the cosmos lesson from the manual
I feel some of the files of solidworks were corropted. i have the same problem before. when i right click on design scenario, it does not open.
i just repaired it. go to add remove programmes and repair cosmos installation.
may be this will fix the problem.
other wise you need a clean installation.
