2 Replies Latest reply on Jan 29, 2018 7:21 AM by Matt Bieringer
    Sketch Trim
    Matt Bieringer
      Hello everyone,
      I am having some difficulty trimming a created sketch via my macro. Attached are images of what I am starting with, what I need and then what my code is outputting.
      I have tried all the different options for .sketchtrim and have tried to move the order which I select the objects. My code below is the only option that outputs anything close to what I need.
      Thank you for your help
      bRet = swExt.SelectByID2("Spline4", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
      bRet = swExt.SelectByID2("Arc1", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
      If bRet = False Then Debug.Print "SP1 Error"
      bRet = swSkMgr.SketchTrim(2, 0, 0, 0)
      If bRet = False Then Debug.Print "SP1 Trim Error"
        • Re: Sketch Trim
          Simon Turner
          Have you tried the other options as defined in the swSketchTrimChoice_e Enumeration?
          You are using "2" which represents swSketchTrimTwoEntities
          Perhaps try 5 or 6.
            • Re: Sketch Trim
              Matt Bieringer
              I tried them all, but I was able to get it to work.
              For some reason the API doesn't like to trim closed profiles, so I changed my circles to arcs and was able to use the Trim Away Outside (5) and that worked great for me.
              bRet = swExt.SelectByID2("Arc2", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
              If bRet = False Then Debug.Print "SP2 & Arc Selection Error"
              bRet = swSkMgr.SketchTrim(5, 0, 0, 0)
              If bRet = False Then Debug.Print "SP2 & Arc Trim Error"
