I'm not quite sure how to use the API for a process. I have a sketch open and I want the user to have a spline sketch entity selected and the api will use the equalsegment applied with user input on the number of sketch segments along the path. I'm not sure how to get the current sketch entity selected for this problem. The API has a vast amount of information and I was hoping someone could guide me in the right direction.
Equalsegment tool for the spline
2017 SOLIDWORKS API Help - EqualSegment Method (ISketchSegment)
Useritemselect? Just want to use the line
if the segment is selected then this will work, i didnt test it but it should
if you want it split into sketch points
Function SplitSegment(ByVal SplitCt As Integer) As Boolean
Dim Part As ModelDoc2
Dim swApp As SldWorks = Application.SldWorks
Set Part = swApp.ActiveDoc
Dim SelMgr As SelectionMgr
Set SelMgr = Part.SelectionManager
If SelMgr.GetSelectedObjectCount2(-1) = 1 Then
If SelMgr.GetSelectedObjectType3(1, -1) = swSelectType_e.swSelSKETCHSEGS Then
Dim SkSeg As SketchSegment
Set SkSeg = SelMgr.GetSelectedObject6(1, -1)
SplitSegment = SkSeg.EqualSegment(swSketchSegmentType_e.swSketchSegmentType_sketchpoints, SplitCt)
End Function
