Sorry guys, I am pretty new to macros - please go easy on me. I thought this change would be simple, but I am having trouble. I have a macro that cycles through the open documents and looks for drawing files, then sets the print options and prints all of the open drawings. I wanted to have a option on the user form for closing the documents after they are printed. I get an error though and I think it has to do with the fact that I am closing a document that the while loop relies on. Here is my code:
Public Sub PrintButton()
If UserForm1.PrintAllOpen.Value = True Then
Dim OrriginalDoc As String
OrriginalDoc = swModel.GetTitle
Set swModel = Swapp.GetFirstDocument
While Not swModel Is Nothing
If swModel.Visible = 1 And swModel.GetType = 3 Then
Swapp.ActivateDoc (swModel.GetTitle)
Call PrintActive
Dim CurrentDoc As String
CurrentDoc = swModel.GetTitle
If UserForm1.CloseDoc.Value = True Then
Swapp.CloseDoc (CurrentDoc)
Set swModel = swModel.GetNext
Wend
If UserForm1.CloseDoc.Value = False Then
Swapp.ActivateDoc (OrriginalDoc)
Else
Call PrintActive
UserForm1.Hide
MsgBox "Print Complete!"
The error I get is:
"Run-time error '-(numbers):
Automation Error
The object invoked has disconnected from its clients."
Can someone show me the code required to close all open drawing files? Or even just point me in the correct direction? Thanks!
Call PrintActive
Dim NextDoc as modeldoc2
Set nextDoc = SwModel.GetNext
swmodel = NextDoc
Wend
Else
Call PrintActive
UserForm1.Hide
ok so what is happening is you are closing the doc which separates it from the COM Boundary, meaning you dont care really it just means you cant destroy something before you try to use it again.
adding the code in bold should fix your issue.. you are getting the next document from a dead document currently this will get it before you kill the document.
