when I tried to push the design I get this.
This is the error I'm seeing after I made some adjustments to the profile.
How can I return board outline?
seems like all I had to do was to rename the file with the prefix "BoardOutline" to correct it.
So far it worked.
안녕.
나는 지금 똑같은 에러가 발생했다.
답변에 대한 내용이 이해가 안가서 그러는데 더 자세히 설명해주실 수 있습니까?
Perfect. In order for the PCB connector to understand your Board, it will be named by default(BoardOutline_ProjectName). Kindly refrain from modifying the name and you should be good to go:-)
Thank you very much.
Warm Regards
Karishma
So far it worked.
