4 Replies Latest reply on Jan 24, 2018 4:22 PM by Matt Mitchell
    3D Sketch Macro not evaluating z coordinates
    Matt Mitchell
      In SW 2017 3D sketch example: http://help.solidworks.com/2017/english/api/sldworksapi/create_3d_sketch_plane_example_vb.htm does not evaluate z coordinates.  i.e. all created center lines are on 0z even if value is modified.
        • Re: 3D Sketch Macro not evaluating z coordinates
          Ivana Kolin
              swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchSnapsHVLines, False
              swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchSnapsHVPoints, False
          ' rest of the macro
              swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchSnapsHVLines, True
              swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchSnapsHVPoints, True
              Matt Mitchell
              It changed nothing about the results.
              Matt
                  Ivana Kolin
                  Option Explicit
                  Dim swModelDocExt As SldWorks.ModelDocExtension
                  Dim swSketchManager As SldWorks.SketchManager
                  Dim swSketchSegment As SldWorks.SketchSegment
                  Dim swSketch As SldWorks.Sketch
                  Dim status As Boolean
                      Dim DefaultAssTemplate As String
                      DefaultAssTemplate = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplateAssembly)
                      Set swModel = swApp.NewDocument(DefaultAssTemplate, 0, 0, 0)
                      Set swSketchManager = swModel.SketchManager
                      swSketchManager.Insert3DSketch True
                      Set swSketchSegment = swSketchManager.CreateCenterLine(-0.082642, 0.005659, 0#, -0.049926, 0.045073, 0#)
                      Set swSketch = swSketchManager.ActiveSketch
                      status = swSketch.SetWorkingPlaneOrientation(0, 0, 0, 0, 1, 0, 0, 0, 1, 1, 0, 0)
                      Set swSketchSegment = swSketchManager.CreateLine(-0.049926, 0.045073, 0#, -0.049926, -0.022634, -0.065874)
                      swSketchSegment.ConstructionGeometry = True
                      status = swSketch.SetWorkingPlaneOrientation(0, 0, 0, 0, 0, 1, 1, 0, 0, 0, 1, 0)
                      swModel.ClearSelection2 True
                      swSketchManager.InsertSketch True
                      'Insert 2D sketch of a circle
                      swModel.ActivateSelectedFeature
                      Set swModelDocExt = swModel.Extension
                      status = swModelDocExt.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
                      Set swSketchSegment = swSketchManager.CreateCircle(-0.056401, 0.005985, 0#, -0.054697, -0.005141, 0#)
                      'Insert a 3D sketch plane
                      status = swModelDocExt.SelectByID2("Line1@3DSketch1", "EXTSKETCHSEGMENT", -5.65609614209999E-02, 3.70796232466087E-02, 0, True, 0, Nothing, 0)
                      status = swModelDocExt.SelectByID2("Point2@Sketch1", "EXTSKETCHPOINT", -5.64010297276809E-02, 5.98490302365917E-03, 0, True, 0, Nothing, 0)
                      status = swSketchManager.CreateSketchPlane(9, 9, 0)
                      status = swModelDocExt.SelectByID2("Plane1", "SKETCHSURFACES", 0, 0, 0, False, 0, Nothing, 0)
                      swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swSketchInference, True
