I just can't believe there is no way to reuse an adapted mesh generated during a multi-day run. Can someone tell me how to save and reuse a large mesh? (no change to geometry).
Even within the run, it looks like after mesh refinement it does not use the conditions from the previous mesh.
thanks
Wendy
you need specify the file under initial conditions - top item on the dialog to reinitialize the mesh with a previous studies results. or select use previous if he mesh has not been changed.
