SW 2017, SP 1.0
Really bizarre behavior I'm seeing. When closing a part or assembly that has been modified (indicated by the * next to the file name), I am not prompted to save the changes and they are automatically discarded. This is normal behavior of the document is read-only, but I am experiencing this with non-read-only documents. I have to manually hit ctrl+S to save the document before exiting, otherwise all my changes are lost.
I've never seen this before. I do need to update to SP 5 so maybe that will fix this problem...
Any ideas?
EDIT. Most of my projects are in 2016 so I just recently started using 2017. I don't recall 2017 ever asking me to save.
Jory, I'm not sure if this is the case but you could check your "Messages/Errors/Warnings" tab to make sure you didn't inadvertently turn off Saving changes to modified documents somehow ...
