5 Replies Latest reply on Jan 22, 2018 6:30 AM by Patrick Peschke
    Solidwork Start parameter?
    Patrick Peschke
      Hello
      I have a question about the additional applications.
      We have two additional applications that are not allowed to start together.
      Is it possible to specify which add-in application will be activated when starting solidwork?
      I thought that maybe it is possible to start pararmeter
      Sorry for my bad English
      greeting Patrick
        • Re: Solidwork Start parameter?
          Alexander Klammer
          Hi Patrick,
          For sure:
          BR
          Alex
              Patrick Peschke
              Hello
              Sorry I may have mispronounced myself.
              We have two additional applications (EPDM and Autodesk Productsteam)
              If both additional applications are active there are problems.
              If I use EPDM then the EPDM add-on should be active and Autodesk Productsteam disabled.
              I thought that could be solved via a VB script or with a start parameter with a desktop link.
              I hope you can understand what I mean!
              greeting patrick
                  Alexander Klammer
                  I understand,
                  At
                  HKEY_CURRENT_USER\Software\SolidWorks\AddInsStartup
                  You can find the AddIns that are Loading at Startup and also change the value here (0 or 1)
                  To find out which addin you are activating/deactivating look in
                  HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\AddIns\
                  and
                  HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\SOLIDWORKS 201x\Addins
                  so you could easily write a small startup script.
                  To check it programmatically via api Elmar´s answer is all you need.
                  BR Alex
                Elmar Klammer
                Hi Patrick,
                To start the addin from within SW use this code. You have to modify the path.
                ' Preconditions: Dll must exist.
                ' Postconditions: Add-in is loaded if user clicks Yes; add-in is unloaded if user
                '                clicks No.
                ' SldWorks::LoadAddIn
                '       0   Success. Add-in load was successful.
                '       1   Add-in not loaded. However, this was not an error condition.
                '      -1   Add-in not loaded. Unknown error occurred.
                '       2   Add-in not loaded. Add-in is already loaded
                ' SldWorks::UnloadAddIn
                '       0   Normal return. Add-in unloading was successful.
                '      -1   Add-in could not be unloaded due to some error condition.
                    ' Path to an existing add-in
                    Const sAddinName            As String = "C:\Program Files\SolidWorks\PDMWorks Client 2008\pdmwaddin.dll"
                    Dim swApp                   As SldWorks.SldWorks
                    Dim nResponse               As Integer
                    Dim nStatus                 As Long
                    Dim bRet                    As Boolean
                    nResponse = MsgBox("Activate(yes)/Deactivate(No) PDMWorks Add-In?", vbYesNo)
                    If nResponse = vbYes Then
                        Debug.Print "Loading: " + sAddinName
                        nStatus = swApp.LoadAddIn(sAddinName)
                    Else
                        Debug.Print "Unloading: " + sAddinName
                        nStatus = swApp.UnloadAddIn(sAddinName)
                    Debug.Print "  Status = " & nStatus
                To set the toggle for startup you use shell script. Use regedit and find the branch
                HKEY_CURRENT_USER\Software\SolidWorks\AddInsStartup\
                There is a bunch of GUID codes. The best way to identify is to go to SW and disable all but one for startup. Then look through the GUID until you find the one with a default value of 1. That's the GUID that you need to use in the code below.
                Dim myWS As Object
                Dim myRegKey As String
                Dim myValue As Integer
                Set myWS = CreateObject("WScript.Shell")
                myRegKey = "HKEY_CURRENT_USER\Software\SolidWorks\AddInsStartup\{1f97d880-9d20-44d9-99bc-5d4b26da2d81}\"
                myValue = 1
                myWS.RegWrite myRegKey, myValue, "REG_DWORD"
