Hi all,
Thanks to the great help here my PDM task worked great for a few weeks, until we updated to Solidworks 2018, which no longer supports ExportFlatPatternView.
I now have to use ExportToDWG2 which is much more complicated to use.
I have attached the relevant code below, which is mostly copied from the example provided in the API help. It seems to mostly be okay, except the last line bRet = swModel.ExportToDWG2 which gets an error "The object invoked has disconnected from its clients". From my understanding this is because swModel no longer exists, but I am not sure why or how to fix it.
Would anyone be able to suggest how to get this working again?
Thank a lot,
Tom.
If sheetMetal <> 0 Then
Dim bRet As Boolean
Dim sfilePath As String
sfilePath = swModel.GetPathName
Dim varAlignment As Variant
Dim dataAlignment(11) As Double
dataAlignment(0) = 0#
dataAlignment(1) = 0#
dataAlignment(2) = 0#
dataAlignment(3) = 1#
dataAlignment(4) = 0#
dataAlignment(5) = 0#
dataAlignment(6) = 0#
dataAlignment(7) = 1#
dataAlignment(8) = 0#
dataAlignment(9) = 0#
dataAlignment(10) = 0#
dataAlignment(11) = 1#
varAlignment = dataAlignment
Dim options As Long
options = 1
bRet = swModel.ExportToDWG2(savePath, sfilePath, 1, True, varAlignment, False, False, options, Null)
