I want to compare several different fan blades to determine which one "moves" more air. I want to output MASS FLOW RATE, but this is only a goal...not an option for results. Doesn't the mass flow rate vary throughout the flow volume just as the density likely varies throughout? Shouldn't I be able to look at a cut or surface plot to see these results?
So if I look at Goal Plots I can see a average, max, and min values for mass flow rate. Is this where I can best see this result?
TIA,
Alex
