I am trying to get this cap to screw onto the end of this bottle.
I used the thread wizard and the same thread type on both parts being screwed together, but when I do a section view it doesn't look like the 2 parts would ever tighten all the way up. I figured I could just lengthen or shorten one of the pieces, but that doesn't seem to work. And I couldn't quite follow anything I googled.
I am going to 3D print these parts and want to print the ends with threads first to make sure it works before wasting time and filament if the threads arnt right.
Please, any help would be greatly appreciated!
Mitch
Mitch,
It will do up tight when the two highlighted faces come into contact with each other assuming the thread is long enough in the cap, which it isn't.
Plus the area highlighted with yellow arrow is way too thin.
