I am having trouble setting up a 3D pdf template. I can get everything to look great in the template, but when the pdf is created all the text will be shifted and different sizes. Tech support says that this is a known bug, SPR#935070 - Text alignment mismatch.
Has anyone else run into this issue? Is there a work around? Somehow I need to be able to create my pdf templates. How do I setup my template so that I know what is shown will be what is generated when the pdf is created? I have seen plenty of sample 3D pdfs that look great and Solidworks comes with templates that work. How do I create my own template that will work?
I am using Solidworks 2017 SP 2.0
Thanks!
Hello Greg,
Did you ever find a solution/work around for this issue? I'm working on a template at the moment and running into similar issues. The issue arises when using different types of text boxes. The custom property field seems similarly aligned in the template and result, but the label area (template text field) moves up and sometimes gets cropped at the top (even though it's in the front and has enough height).
Template:
Result:
Result after changing Custom Property field to Template text field
