Can't seem to figure this one out. Item 14 in the assembly shown below is a self locking cap screw I downloaded from Mcmaster Carr
But it's showing up as partially dashed in my drawing. How can I get it to show up as solid lines?
have you tried to rotate the bolt slightly to see if it gives you different results? I have had odd glitches like this in the past, and deleting the view and undoing the delete has fixed random issues. Also, I see that it is a cross-section. You may be cutting right through the very edge of the bolt, and it is leaving just a few threads and faces to be seen. That's the best ideas I have got, best of luck to you!
Try excluding the part of the section, see if it shows up afterwards.
Edit: This might sound stupid especially since it's been a while since you asked the question but have you tried restarting your SolidWorks? I often have problem with section views after working for a while on the same session and a restarting SolidWorks fixes it usually.
If you'd like to know if it is something related to your settings, I suggest closing SolidWorks, launching SolidWorks RX and then launching SolidWorks in Safe mode.
Solidworks Rx is a separate program that was installed when you installed Solidworks. Check your start menu.
https://www.javelin-tech.com/blog/2016/06/solidworks-rx-safe-modes/
To attach files you have to click "Use advanced editor".
Pretty fricking stupid, and I'm tired of having to tell people that. Not that it's the people's fault. It's a stupid interface design.
Jim Wilkinson I don't suppose there's any way in the Jive settings to disable the crippled editor? I can think of zero downsides to making it go away in every context. Especially in your Inbox view. If you start typing a reply to something in there, the "advanced editor" link doesn't even show up. If you get done typing a response and then you want to attach a file, you have to copy what you typed and navigate out to the actual thread and paste there.
Heck, even adding the "attach" button to the crippled editor would be a good step.
I don't believe there is a way to do this, but Richard Doyle is the main owner of the forums, so he should confirm.
By the way, there is at least one benefit of the non-advanced editor; it does the reply right inline of the thread/inbox so you can look back and reference other replies, etc. The advanced editor is on its own page with ONLY the one post/comment you are replying to. So the advanced editor in its current incarnation is annoying because if this and when using the advanced editor, I often have to open up the full thread in another browser window to review other comments/replies when forming my response. Yes, I wish the forum interface would just have the full editor inline with all options (replacing the simple editor), but there must be some technical reason/limitation why that is not done in the forum platform.
Jim
Thanks,Jim
I seem to recall that it did at one time, but pages also took longer to load. If I'm right about that I'll take faster loading in return for not having the "Attach" link always active. Although it would be nice if the "Use advanced editor" link actually looked like a link.
Do you have tangent edges set to Removed? This could cause that, due to how that bolt appears to be positioned.
