Where did you add the Cut - did you create a plane or select the flange face or did you edit the flange sketch and insert you Cut Profile Sketch there....
I selected the flange face to add a cut. And as soon as I adjust the bend line sketch. The cut stays with the 1st original plane. This also happens when I trying to add to the same flange plane.
I wonder if it is a sitting in options. Because I never had this issue with previous SW versions.
Thank you
How is the cut dimensioned?
Steve C
