Anyone able to edit the macro below to save as pdf with current sheet revision (from drawing file properties)?
Current macro saves the drawing as pdf, but uses "revision" from custom properties in the 3d model.
Option Explicit
Dim sPathName As String
Dim sRev As String
Dim nRetval As Long
Dim bShowMap As Boolean
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportData As SldWorks.ExportPdfData
Dim boolstatus As Boolean
Dim swCustProp As CustomPropertyManager
Dim valOut As String
Dim resolvedValOut As String
Dim swView As SldWorks.View
Set swModel = swApp.ActiveDoc
sPathName = swModel.GetPathName
sPathName = Left(sPathName, Len(sPathName) - 7)
If (swModel.GetType = SwConst.swDocumentTypes_e.swDocDRAWING) Then
Set swView = swModel.GetFirstView
Set swView = swView.GetNextView
Set swCustProp = swView.ReferencedDocument.Extension.CustomPropertyManager("")
swCustProp.Get2 "Revision", valOut, resolvedValOut
bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
Set swExportData = swApp.GetExportFileData(swExportPDFData)
boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
boolstatus = swModel.Extension.SaveAs(sPathName + "-" + resolvedValOut + ".PDF", 0, 0, swExportData, 0, 0)
swApp.SetUserPreferenceToggle swDXFDontShowMap, False
swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
If boolstatus Then
MsgBox "Save as PDF successful, WOOT!" & vbNewLine & sPathName + "...PDF, DWG, DXF"
Else
MsgBox "Save as PDF failed." '
Else
boolstatus = swModel.SaveAs4(sPathName + ".step", swSaveAsCurrentVersion, swSaveAsOptions_Silent, 0, 0)
Give this a shot, I've not tested it though.
