I have an assembly with two parts in it. They are inserts.
The assembly will be used to make new inserts with different shapes
cut into them. I would like to create an assembly template with
these two parts in it, but I keep getting a message that says that
"A document which references other documents may not be saved as a
template". Is there anyway around this?
Also, it seems you may be using templates to do something that just isn't necessary. All you need is an assembly of your components to start with and them "save as" to whatever new name you like for the specific changes for that file.
